Air pump questions.
  • Thread starter Thread starter Teeto's5.0
  • Start date Start date Nov 20, 2005
T
Teeto's5.0
44
Janesville, WI
Nov 20, 2005
  • Nov 20, 2005
Hey all, just wondering what happens if you remove the complete air pump set up on a 89 stang? I want to clean up the engine compartment and all the extra stuff looks cluttered. Does this cause problems to remove the set up? Will there be codes or mistereous drivability problems? My car runs with an off road bbk h pipe. I am trying to detail the engine compartment and just want all the extras to dissappear. I don't need a smog test but I will keep everything around in case it needs to be tested. Thanks.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Nov 20, 2005
  • Nov 20, 2005
If you have an offroad pipe like you say, you can completely remove it, and use a shorter belt.
Make sure you plug all the left over holes.
There is a tube that goes from head to head int he back, also can be removed and plugged with ford head plugs, but it's a bitch with the engine in the car.
T
Teeto's5.0
44
Janesville, WI
Nov 20, 2005
  • Nov 20, 2005
Thanks, where can I get the correct thread plugs? Also what size belt is needed? Thanks again.
T
Teeto's5.0
44
Janesville, WI
Nov 20, 2005
  • Nov 20, 2005
Also what do you use to plug the small tube on the h-pipe?
9
95cobradude
Banned
Apr 1, 2005
194
long island, ny
Nov 20, 2005
  • Nov 20, 2005
get a smog pump delete pulley, thats what i did in my 95 cobra, i ditched all that smog bull****.
2000xp8
Aug 8, 2003
8,075
1,658
194
NJ
Nov 20, 2005
  • Nov 20, 2005
Don't do the smog delete pulley, on a fox it still looks a bit cluttered. Plus there really is no reason to.
Belt size with Underdrive pulleys is going to be somewhere around 765 k6, but i'm not totally sure, it's worn off my belt.
My x pipe had a rubber tube coming off of it, i stuffed something round in it, and pipe clamped it.
Your ford dealer has the plugs to plug the heads, they are a regular for part, and most dealers stock them, I don't know the part numbers offhand.
T
Teeto's5.0
44
Janesville, WI
Nov 20, 2005
  • Nov 20, 2005
Ok I could just match up the bolt size with a bung plug at the hardware store. is the 765 k6 a belt part number?
2000xp8
Aug 8, 2003
8,075
1,658
194
NJ
Nov 20, 2005
  • Nov 20, 2005
I belive it's the lenght in inches, which would be 76.5 inches and k6 for 6 rib.
T
Teeto's5.0
44
Janesville, WI
Nov 20, 2005
  • Nov 20, 2005
Cool thanks for all the info! Now Im gonna go rip that beast out!! Thanks again.
T
Teeto's5.0
44
Janesville, WI
Nov 20, 2005
#10
  • Nov 20, 2005
  • #10
O.k. I got it torn down and I found that the hole in the back of the heads should be a 1/4 pipe thread. Now I just need a belt!
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
