- Sep 14, 2016
- 3
- 0
- 1
Hi All,
I'm having an airbag issue I could use some help with. If the key is in run position the airbag light will go out after initially coming on with all the lights then will go out and stay out. I waited several minutes to make sure the code didn't pop up again. Code 6 pops up only when the car is started. Any help will be appreciated!
Thanks!
90 lx 5.0 5spd
mostly stock
bolt ons: GT-40 upper and lower, 70mm TB and EGR spacer, full exhaust, 95 front brakes, 3 core radiator, cold air fender kit, electric fan.
IRS
Thanks!
90 lx 5.0 5spd
mostly stock
IRS
