new caster plates installed
installing the strut and installing the screw in clamp and coil springs
installing the pinto rack along with the clamp for the rack from aje
Since I went with the SN95 spindle assembly I put on the hub from a set of Cobra calipers and slot/ drilled rotors
if you do the front you might as well do the back right!
column modified
installing the D-shaft
had to go from a front sump to a Rear sump pan. We had to get a certain pick up tube to clear the stud girdle and nock a little dent in part of the stock 90's pan for it to clear along with weld in a bung for the oil drain from the turbo.
engine reinstall
header install... look at all that room. I could of installed the headers on the block then installed it but we didn't want to chip any of the paint.
column modified
engine reinstall
