Alarm Recommendations
  • Thread starter Thread starter Bullitt
  • Start date Start date Oct 27, 2007
Bullitt
Packin' Heat
2,743
Houston, TX
Oct 27, 2007
  • Oct 27, 2007
Mustang is getting a paint job now and the doors are all apart so I was considering power door locks with remote unlock. Since my Sport Trac was broken into last night, in which they stole my work laptop, leather jacket, and $200 in Mustang parts !! I'm thinking it's time for a really good alarm.
What are everyone's recommendation?
I was considering the kits from A1 Electric.com, but it doesn't seem to be the nicest alarm... I want something that'll be compatible with a power door lock kit. Is this usually an all-in-one deal or something you can piece together???
Thanks for the help!
iskwezm
4,159
20
79
Rowland Heights,California
Oct 27, 2007
  • Oct 27, 2007
Anything from DEI (Viper,Python,Hornet etc.) They caryy a lifetime waranty. I could probably get you a alarm (DEI or Clifford), and door actuators at wholesale and you have it installed over there.
I also know of dealers in your area that are trustworthy.
bnickel
5,640
lubbock, texas
Oct 27, 2007
  • Oct 27, 2007
yeah you can get an alarm that will be compatible with any power lock system. get the power trunk release from a 70's ford out of the wrecking yard and have a power trunk as well. pretty much any ford will have the one you need too. i have an Ungo keyless entry on my 86 town car and the trunk release option is really nice to have. i have the power release for the stang too but decided to hold onto it and use it on the 69 cougar project instead. i plan on getting the power door lock kit from these guys
http://www.autoworksracing.com/keyless_entry_door_lock_system.htm
it's not cheap but i don't really care, it looks better and stronger than most of the stereo shop installs i've seen, or other mustang owners either for that matter
Bullitt
Packin' Heat
2,743
Houston, TX
Oct 27, 2007
  • Oct 27, 2007
iskwezm,
PM details of what you can get, I'm very interested!
bnickel,
I'll look into those trunk releases, I assume install is fairly easy? I do really like those bolt-in powerlock kits, open to options...
Thanks for the feedback.
bnickel
5,640
lubbock, texas
Oct 27, 2007
  • Oct 27, 2007
yep, 2 bolts and a couple wires and deciding where to install the release button in the interior, probably the glove box
stonecoldtx
214
Dallas, TX
Oct 28, 2007
  • Oct 28, 2007
I have a '70 Coupe, and used the B6000 system from A1electronics.com--it had the power door lock system and the availability to add a power trunk release solenoid.
I installed the power lock solenoids FIRST, got them working and THEN installed the alarm system, wiring it in as the instructions describe.
The locks operate in tandem--that is, if you lock ONE, it causes the OTHER one to lock as well.
After I got the locks installed and working, and started installing the alarm, I figured out what I needed to do to install a lock switch (so I could lock/unlock the doors with a switch instead of pushing down on the knob--useful if you're sitting in the seat, as it's a little difficult to reach around to lock/unlock with the knob), and put one in the console.
One other thing--there is a little lever on the door latch that causes the door to unlock if you have the door open, lock the door with the knob and close the door, UNLESS you hold down the button on the exterior handle--I disabled that so that I could just lock the knob and close the door.
It's pretty simple to do--you just have to bend the lever a bit so that it won't be contacted by the mechanism. It's my understanding that this was purposely designed to do that, as apparently people had problems locking themselves out of their vehicles--I don't have that problem, because I ALWAYS have my keys either in my hand or in my pocket BEFORE I close the door. Those that have problems sometimes locking their keys in their car might want to skip disabling this feature.
For the remote trunk release, I used a reproduction stock remote trunk latch that has the lever for the cable-operated remote release, and just wired in the solenoid from the trunk release kit, and connected it's cable directly to it.
I got the reproduction from a vendor on E-Bay, and it was a brand new Scott Drake part--so far, it works great!
I haven't yet gotten the vibration sensor configured quite right yet, but it's easily adjusted, and I installed the supplied hood sensor too.
One great thing about this system is that it also has the "Dome Light Supervision" option, which turns on your dome light for 30- or 60-seconds after you disarm the system.
I installed the alarm module up under the center of the dash pad, so that the antenna would be as high and as centered as possible for the remotes--AND--so that it would be extremely difficult for thieves to get to it!!
The only BAD things I could see about the alarm are that the instructions that come with it are somewhat vague in places, and that the wiring is VERY small gauge--probably 24 or even perhaps smaller.
As compared to a DEI system, I'd say it's probably on a par with their basic system (no 2-way pager option, no remote-start option, neither of which I feel I need), but for the price, I think it's a bargain.
iskwezm
4,159
20
79
Oct 28, 2007
  • Oct 28, 2007
Bullitt said:
iskwezm,
bnickel,
i'll be be going to my distributor to pick up some stuf for Suki243 on saturday so i'll see whats in stock
iskwezm
4,159
20
79
Nov 4, 2007
  • Nov 4, 2007
Bullitt said:
iskwezm,
pm on its way
J
89 mustang alarm install to lock and unlock
  • jk66
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2026
jk66
J
9
1995 Mustang GT Crank no Start
  • 95gtV
  • Sep 1, 2023
  • 1994 - 1995 Specific Tech
3K
1994 - 1995 Specific Tech Dec 4, 2023
SRago
SOLD 1993 Mustang Cobra / 114K miles / Modified / Fort Lauderdale, Florida.
  • Naja
  • Oct 4, 2023
12K
Fox Body Mustangs For Sale (1979-93) Feb 26, 2025
Naja
Viper 791xv Alarm system problems remote start and door trigger false alarm
  • sceprent
  • Jul 2, 2021
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Jul 2, 2021
sceprent
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
