  • SN95 4.6L Mustang Tech
Alignment Question
  • Thread starter Thread starter SteedaGT9150
  • Start date Start date Jul 29, 2009
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Jul 29, 2009
  • Jul 29, 2009
ok so i had to put my buddys wheels on for inspection because my tires were too low. had no problems with that what so ever. so today i put back on my roush wheels, and its pulling to the left noticably. the only thing i did was add air to my tires (all 30 psi) and i got a new tire put on one of the wheels. whats going on? tire size is 265/55/18 all around.
Waterdrake
12
Atlanta, GA
Jul 29, 2009
  • Jul 29, 2009
are all the tires the same brand? the same size tire's actual size will vary slightly between manufacturers and may cause a slight pull. that, or it sounds like a caster or camber change happened somehow. other than that...
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Jul 29, 2009
  • Jul 29, 2009
the rears match and the fronts match. i dunno why it would happen all of a sudden... i didnt change anything.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jul 29, 2009
  • Jul 29, 2009
it is called a radial tire pull. swap the front tires side to side and see if the pull changes directions. it will always pull to the side of the bad tire.
no real way to fix it. sometimes you can flip the tires on the rim and it will go away but it only works about 50% of the time
is the new tire on the LF?
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Jul 30, 2009
  • Jul 30, 2009
the new tire is on the passanger side rear. the old passanger rear moved to the front. driver side tires stayed the same.
D
Dragstr05
643
Stafford VA
Jul 30, 2009
  • Jul 30, 2009
+1 you read my mind.
H
Best tire size for 91 Fox 18x9 wheels. On coilovers
  • hassler
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
KRUISR
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
