Alignment Specs
  • Thread starter Thread starter sen2two
  • Start date Start date May 20, 2017
sen2two
I've been lubing and pulling it all morning
5 Year Member
Jul 18, 2013
396
58
59
May 20, 2017
  • May 20, 2017
I'm in need of an alignment. I just installed coilovers up front along with some caster camber plates.
I'm looking for some specs to give to the alignment shop to keep this car from tramlining as mush as possible. I had 275 wide tires front and rear and it was DANGEROUS like that. I swapped to pro stars with skinnies up front to minimize that.
Now hopefully with the proper adjustment, i will be able to run wide tires front and rear.
Anyone know proper alignment specs for good handling?
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
May 20, 2017
  • May 20, 2017
Usually tramlining is a combo of events. Usually it's tires, but sometimes it's too much camber, not enough caster, some toe-out, or a combo of the above.
This article gives a bit of insight to a stock type of alignment setting. Adjustments beyond that require some experimentation.
http://www.mustangandfords.com/how-to/chassis-suspension/m5lp-0207-front-end-alignments/
I actually bought my own alignment aides and just starting to play with a few settings myself. I'd stop short of making recommendations as I'm waiting on installing some C/C plates, and then adding a little more caster and have my toe set at 1/16" in. I habe my camber at -0.5 degree, but I may change this to -1.0-1.5
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Foxbody adjust alignment
  • Creomod
  • Jun 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2025
2000xp8
Suspension Setting Front Alignment - Do I care about the rear's thrust angle?
  • dan50
  • Nov 27, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Kid wita 5oh
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
