  • 1994 - 1995 Specific Tech
alphabet cams
  • Thread starter Thread starter red95aodevert
  • Start date Start date Mar 22, 2004
R
red95aodevert
64
Redford, MI
Mar 22, 2004
  • Mar 22, 2004
I have a 95 AODE with 3000 stall converter and 4:10's and have been considering adding a cam . I can get many used cams like the "B, E, F and X" but have read on here several times about people having idle problems with the alphabet cams. I already have a custom chip from JMS and don't mind getting it re-burned since I will be doing other mods that will require a re-burn anyway. My question is with the chip will I have idle problems or any problems for that matter.
stang_gt_1994
2,723
Powder Springs, GA (30 min. from Atlanta)
Mar 22, 2004
  • Mar 22, 2004
I would not suggest getting a cam if your running stock heads. It is really a waist of money, all you will get out of it is sound. If you do decide to get one then a custom chip will get rid of all you idle problems.
R
red95aodevert
64
Redford, MI
Mar 22, 2004
  • Mar 22, 2004
I will be doing heads as well. I'm not sure what heads but most likely P's due to budget.
95snoozer
2,572
RCR
Mar 22, 2004
  • Mar 22, 2004
all you will get out of an e cam is a car that pulls al the way to 6k
my car peaks form around 5k-5400 and then slowly fades offf. I shift a lil after 5600.
since you have a stall, you are fine with the bottom end and will make yoru car scream in 3rd on the highway.
but what heads are you looking at and maybe we can pic out a better cam. dont let some of the guys on here influence you into getting a small cam......
everybody seems to be so scared about the way it will drive.
I am doing P heads as well. definietly go with an AFM b-31 or b21 cam depending on iff you have 1.7s or 1.6s when you swap heads.
also get good springs
that cam with good enough springs will yank your motor to 6200..... and your torque will be awesome.
FordStang
862
Orange Park, FL
Mar 22, 2004
  • Mar 22, 2004
i just installed the B cam along with tons of other things(see Sig) And it didnt wanna idle first...but Boost up the idle to about 850ish Runs fine now with Fuel Pressure at 40 PSI
ProKiller
3,064
15
78
PA
Mar 22, 2004
  • Mar 22, 2004
i have the F-cam and man does it rumble. makes good power, but then again its hard to tell between the cam and the blower. the idle is about 950. it surges a bit when u first start it up but then purrs like a kitten. it doesn't start making good power till like 3000 rpm which is nice for a street car so u can drive it normal without any problems. it doesn't like to go lower than 1750 rpm so i would think that with the auto, it might be a problem but i don't know. you would need to get your chip reflashed to fix the idle.
randomjoker
427
Oklahoma
Mar 22, 2004
  • Mar 22, 2004
v-2!!! boo do you not like the sound of the s/c whining away!
ProKiller
3,064
15
78
PA
Mar 22, 2004
  • Mar 22, 2004
1. it came with the car
2. no i don't like the constant LOUD whistle
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
Holley High-ram tuning settings
  • spencergt66
  • Apr 1, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jun 19, 2026
spencergt66
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
