Alright, It runs, but now it vibrates bad
crogers813
48
Alright, It runs, but now it vibrates bad and A/C compressor won't engage
Previous post http://www.stangnet.com/mustang-forums/814086-help-no-spark-all.html
Alrighty, finally got the car to start. Ended up being a bad (new) distro. So the rebuild is basically complete. Now I still have 2 issues.
1. it vibrates really bad at anything over 3000rpm. Like the whole car shudders and shakes. (all new motor mounts and trans mount + driveshaft + clutch, flywheel)
Any thoughts?
2. Trying to get the a/c charged, and I can't get the compressor to engage. I have jumped the low pressure switch, and it has 13 volts. There is no voltage at the plug that goes into the compressor.
What to do?
Thanks a bunch guys.
Chris
if it's vibrating sitting still, look at the harmonic balancer. with the engine running, the hb might be wobbling. with the engine off, look from under the car, between the hb and the oil pan, you need to look for rubber squeezing out of the hb.
for the a/c. look at the ccrm for a bad relay. if that's the prob you'll have to replace the whole ccrm as it's not repairable.
Chris
What flywheel did you use? A couple of months back I installed a new flywheel from kragen \oreillys and a king cobra clutch and it vibrated exactly from 3,000 rpm and up it ended up being the flywheel we when back to kragen and got it swamped and it did the same thing with the second one.We ended up going to the junkyard and getting one off another mustang and the vibration went away
This is the flywheel
Ford Mustang 1986-1995 5.0L SPEC 50oz Billet Steel Flywheel
Clutch
Ford Mustang 1986-1995 5.0L Stage 2+ SPEC Clutch
The guys at TrePerformance recommended this combo to me for my total plans for the car. And yes, I do have a 50 oz imbalance. It's just so much hassle if it is the flywheel. The HB is new, but it is one of the Professional Products 90007 - Professional Products PowerForce Plus Harmonic Dampers so never sure about the qaulity. I just couldn't afford a $300 one at the time.
Any additional thoughts or is flywheel the consensus?
Also, anyone got a clue on the A/C problem.
CCRM is brand new. All KOEO codes are PASS. Only KOER codes is EGR missing and rich fuel mixture(I'm assuming because it needs a computer tune)
