altenator probs
  • Thread starter Thread starter notch88
  • Start date Start date Nov 27, 2005
N
notch88
18
  • Nov 27, 2005
hey guys....i think it may be time for a new altenator....when im idling my voltage guage will read low and then regualar low and then regular it keeps jumping and my lights dim and brighten when it does this....i dont think the altenator has enough amps...right now its prolly only like a 60 some amp altenator....are these signs that i need a new and upgraded one? Also, what kind of altenator you you recommend i want somten cheap with at least 100 amps...? i have a stock 5.0 motor.
thanks guys i appreciate the advice.
HISSIN50
34
129
Nov 27, 2005
  • Nov 27, 2005
Notch, you can have a parts store test your charging system if you want. Does your idle surge while the volts go up and down? You dont have turn signals on when this happens, or anything that is variable (like a big sub hitting)?
I would go with a 3G 130 amp alternator. They were stock in 94-95 stangs and some other Fords. You can get them wound as high as 200 amps or so.
Good luck.
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
  • Gulftown980x
  • Jul 29, 2026
squeak93
