altenator probs
notch88
18
hey guys....i think it may be time for a new altenator....when im idling my voltage guage will read low and then regualar low and then regular it keeps jumping and my lights dim and brighten when it does this....i dont think the altenator has enough amps...right now its prolly only like a 60 some amp altenator....are these signs that i need a new and upgraded one? Also, what kind of altenator you you recommend i want somten cheap with at least 100 amps...? i have a stock 5.0 motor.
thanks guys i appreciate the advice.
Notch, you can have a parts store test your charging system if you want. Does your idle surge while the volts go up and down? You dont have turn signals on when this happens, or anything that is variable (like a big sub hitting)?
I would go with a 3G 130 amp alternator. They were stock in 94-95 stangs and some other Fords. You can get them wound as high as 200 amps or so.
Good luck.
