Alternator connector caught on fire.
88 Fox GT
1,674
Iowa
So awhile back my alternator caught on fire and completely toasted the connector, so I think I found a replacement. Is this the proper connector that connects to the top of the alternator?
Thanks.
Agreed with Bernie. If the connector with the stock charge-wires and stator-wire burned, that looks like the right one. Otherwise, you need the other connector (I think they call it a regulator plug).
Do we dare ask about the fire? Hope it was no biggie.
Good luck.
EDIT: I type slow. :bang:
Good luck.
I am not sure what the wire is called, but the one that burned is located on the top of the alternator.
The fire? Really wasn't a big deal. I was driving the car to work and smelled hot electrical which was immediately followed by smoke in the interior. I pulled over and popped the hood. The connector and the insides of the alternator were on fire. So, I used a coat out of my car and smothered it out because I had nothing else. Luckily I wasn't far from home. :D
My guess is that the alternator shorted out or something and the wires got so hot that that crappy material on the connector just caught on fire.
Ford has had a lota trouble w/ those connectors. Anytime we replaced one it ALWAYS came w/ a new connector to be installed.
SD, that sucks. You can also use a first-baseman's mitt to put out a fire. Dont ask...... :p
I agree with Bernie. I just replaced my reg plug (not the one you are replacing) on the 94 because even it looked like poo. All the wires' insulation was vulcanized. I think next time I will try the harness from FFI (It looks really beefy and is recommended by 04Sleeper). But for that plug you need, I dont know of any upgraded pieces......... I guess the point was that as long as you are swapping one plug, maybe you want to renew the other one, for a few years of non-worries.
Good luck.
