i have a ford 302 non roller cam the block is stamped d4de and i can look up the heads too if needed,
the issue is that the alternator is slightly off when mounted with the current bracket/set-up. Its chewing up the belt and it wont even charge, what bracket should i run to get this thing to work correctly, btw the alternator is a ford 3g, thank you for all and any help
