BAKER7598 Founding Member Sep 6, 2001 156 0 16 Summerville, SC Aug 3, 2007 #1 Aug 3, 2007 #1 Will the SN95 Alternator pulley work on my 93 w/out charging issues? I had to replace my old 130 with a new one which came with the SN95 pulley. My old 130 had the stock 93 pulley on it.
R r.barn5.0 New Member May 21, 2006 107 0 0 Aug 3, 2007 #2 Aug 3, 2007 #2 you're fine make sure you have pulley to alternator clearance. sometimes Fox pulleys need a small washer/spacer for pulley clearance on 3G's
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,372 18,120 224 Massachusetts Aug 3, 2007 #3 Aug 3, 2007 #3 If you have stock pulleys, you should be fine. The SN95 pulley is a 3" pulley. The fox pulley is slightly more then 2". If you have underdrives, it may suffer a bit. Summit sells ASP alt pulleys in a few sizes. The smallest they have is 1 7/8 which is perfect if you run underdrive pulleys
