What is the stock alternator in a 90 GT and what would be a good brand of alternator to get and also how many amps should it have? I currently have a stock alternator with under drive pulleys and sometimes when I turn it on it gives out.
mustangsquared said:The stock is a 65 amp...get a PA performance 130 amp 3G (can get them at Autozone since they come in 95 stangs)...upgrade your alt to starter relay wire with a 4 gauge, starter relay to pos battery with a 2 or 4 gauge, and upgrade the neg battery to block with a 4 gauge wire. You will see a huge difference. I get 16 volts at idle. Chech sig..have similar mods.
5spd GT said:Alright...I got the 4 guage wire from the alternator to the starter relay (solenoid)...but haven't did any other wires to anywhere else...
I dont' have any more "room" on my starter solenoid for wires...what can I do to extend that?
So I put another 4 guage wire on the starter solenoid and then put it on the positive battery and then put on a 4 guage wire and bolt it to the block (where at on the block)...do I leave my stock battery wires?
The Pa performance instructions said nothing about doing all that...I did what it said and it didn't mention any of this...
Blandnuts said:The site jrichker mentioned gives you all the info you need.
jrichker said:The stud on the stock starter relay is a little short to add many extra wires. I have been told that the 93 relay had a longer stud.
If you have the inline fuse near the starter relay, bolt some of the extra wires on it. Use the some stud that gets the power feed from the battery.
mustangsquared said:5spd GT, Not to call you out but the negative should not be connected to the starter relay...it has to go to the block to complete the circuit. Positive battery cable to starter relay. I think TMOSS has a diagram on the "useful" webb site. The realy needs power to work correctly and the starter is ground through its retaining bolts.
mustangsquared said:Yeah...some people get upset when you disagree with them just wanted to make it clear I was not trying to be a d!@k. No biggie on getting backwards I forgot what the stock spark plug gaps was and gapped mine .20 too small....too much crap floating around between my ears....![]()
