Clay, for a true 3G (130 amp alt), you can use 4 AWG cable (rated for ~135 amps over the distance you need it to go. The stocker is only about 6 AWG anyhow) and a fuse that is rated for your weakest component. If using a 4 AWG [ahem, fine stand] cable, you should be ok with a 125 amp slow burn fuse (that slow burn part is real important). Grab a 140-150 amp fuse for a spare (I keep one in the glove box. I'll be going to a resettable circuit breaker eventually however). I say this because our alts can actually put out more than 130 amps, so there's a chance the 125 could blow. Or just use a 150 amp fuse in the first place. Your call. I'd use a 125 and if it blows, go with the bigger one. Unless you have a crap load of stuff, you should not blow the fuse, and given the recently issues, it's nice to have the thing fused on the tight side, IMHO.
Good luck.
