Alternator Wiring - Hot or Switched?
  • Thread starter Thread starter Vipersix
  • Start date Start date Jun 6, 2008
Vipersix
434
Clarksville, TN
Jun 6, 2008
  • Jun 6, 2008
From what I can gather from the wiring diagrams I have amassed, the alternator is connected to the hot bus but it almost seems like it should be on the switched bus. Is this correct?
HISSIN50
34
129
Jun 6, 2008
  • Jun 6, 2008
It's simpler to not run the charge cable through an ignition-hot distribution point. With the exception of a diode going bad, the regulator functions a bit like a relay anyhow.
1993SSP
1,194
Ky
Jun 6, 2008
  • Jun 6, 2008
I had wondered the same thing, I put on a 3g on my 85 model, ended up only wiring up one 12v switched to it
Vipersix
434
Clarksville, TN
Jun 6, 2008
  • Jun 6, 2008
I realize the theory behind the single-wire alternators is that the relay is automatically opened once the pulley begins to spin, but it almost seems like there would be some leakage in the circuit somewhere which would drain the battery a bit. But I've pretty well decided to just leave it on the hot battery bus as I originally intended.
Thanks.
HISSIN50
34
129
Jun 6, 2008
  • Jun 6, 2008
Thanks.
The aforementioned diodes keep the battery from backflowing when the car is off.
I have no idea what you were wanting to do (I thought this was a theory thread). If you want to remove some wires, you can loop the stator circuit and connect the sense wire to the hot-lug on the 3G. Just be sure the charge cable remains in impeccable condition since you have basically removed the remote voltage-sensing function. You'll still have the OEM excite wire connected (labeled I on your regulator).
Vipersix
434
Clarksville, TN
Jun 6, 2008
  • Jun 6, 2008
You could possibly conceive this as a theory thread since I have no Ford electronics to deal with. The question is simply how best to wire an alternator. Running a single wire from the alternator directly, in essence, to the battery is sufficient. I was trying to decide if that single wire should be switched or constant.
HISSIN50
34
129
Jun 7, 2008
  • Jun 7, 2008
Gotcha. In that case I like your thinking - you dont want to start making unnecessary impediments to the flow of high current. The one time a switched mechanism might help is if a diode went south, but IMHO it's not worth reconfiguring a charge circuit for such a situation.
You could use a circuit breaker instead of a fuse or fusible links if you want a quick way to divorce the alternator from the battery.
Resolved 83 alternator wiring harness
  • sparten5000
  • Aug 2, 2026
Fox 5.0 Mustang Tech Aug 23, 2026
limp
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical Starter solenoid green wire?
  • 387lx
  • Jun 1, 2026
Fox 5.0 Mustang Tech Jun 2, 2026
AeroCoupe
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
