ALTEWRNATOR?
  • Thread starter Thread starter 1991GreeNLX
  • Start date Start date Oct 25, 2004
1 of 2 Next Last
1991GreeNLX
129
Houston TX
Oct 25, 2004
  • Oct 25, 2004
which alternator did yall go with how many amp's and how much did it cost i just bought a set of UD - pullies and i have a stock alterantor and i wanna swap out the stock alternator would a 130 amp be to much?
D
Daggar
3,902
  • Oct 25, 2004
If you can't spell it you can't fix it. hehe
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 25, 2004
  • Oct 25, 2004
Ah...we all get in hurry to type something...grammer errors happen...
Anyways I bought a 3g alternator from www.paperformance.com along with their "4g wire upgrade kit"...
The alternator and wire upgrade kit comes with full color instructions and I did the install pretty easily and I'm "wiring" retarded...
I bought the 130amp alternator though you can go bigger by getting 160 or 200amp Alts...
You will need to upgrade the fuse and some of the wires to bigger guages but everything I listed above (alt and wire upgrade kit from them) had everything I needed for the install...
It is one of the best mods you can do if you have things like a sound system, a/c, electric fan, etc...
Good Luck
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 25, 2004
  • Oct 25, 2004
Here's websites with pictures of the 3G (94 Mustang and later 130 amp alt) installation procedure...
See http://www.geocities.com/smithmonte/Auto/3G_130A_Alternator_Upgrade.htm - all the tech data you could ever want to know
OR
http://www.mustangcentral.net/tech/alternator.html - excellent pictures of the installation
See these sites for the right way to do the wiring. Some people will tell you that you can skip the wiring upgrade, but it will catch up with you sooner or later. A fire in the wiring harness is ugly and expensive.
Under no circumstances connect the two 10 gauge black/white wires to the 3G alternator. If the fuse blows in the 4 gauge wire, the two 10 gauge wires may be overloaded to the point of catching fire and burning up the wiring harness.
Figure this:
Ignition system & computer = 12 amps
Fuel pump = 12 amps
Exterior lights = 15 amps
Fan (heater or A/C) = 15 amps (can run between 5-25 amps depending on setting)
Radio & instruments = 10 amps
Wipers = 10 amps
That's grand total of 74 amps from a 65 amp alternator. Talk about overdrawn at the bank!
See WWW.partsexpress.com for the fuse & fuse holder.
Fuse = http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=071-952
Fuseholder = http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=263-630
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 25, 2004
  • Oct 25, 2004
The paperformance alternator/wire upgrade kit comes with everything you need...the instructions are very clear and it comes with everything you need right down to the zipties...so you don't have to shop around for parts and take a chance on getting the wrong crimp/wire/etc...instead it is easier to get all the right parts at once
R
ratrapp
510
buena vista,va
Oct 25, 2004
  • Oct 25, 2004
i bought a used 3ga (130 amp) for $40 and the paperformance wiring upgrade kit.i have around $100 tied up in mine.it still charges great even with my march u/d pullies.
04sleeper
2,674
14
89
Dallas, TX
Oct 25, 2004
  • Oct 25, 2004
Got my SN-95 130 Amp alternator from Autozone $109 Lifetime warranty.
Got my 4 gauge wire and connectors from a Marine center. $25
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Oct 25, 2004
  • Oct 25, 2004
Got mine and the wire upgrade from www.pa-performance.com. 95A - no cutting of the bracket required. Excellent quality. Idiot proof instructions. Worked so well I didn't even shop my replacement mini-starter. Just bought it from PA-Performance.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 25, 2004
  • Oct 25, 2004
Does your lights dim at idle...mine does...I have the 130amp alternator with March underdrives also...I guess my only option to fix that is get an overdrive pulley for it...though it voids the warranty...
N
notchman90
87
long isle, ny
Oct 25, 2004
#10
  • Oct 25, 2004
  • #10
i have a 150 i bought from this place in texas, alterstart, lifetime warranty not bad price 135 shipped
89roadster
1,124
Kent Island, MD
Oct 25, 2004
#11
  • Oct 25, 2004
  • #11
Another for pa-performance. I have the black magic electric fan can run the head lights, wipers, defroster, and cd player all while idling for 30 minutes in traffic without lights ever dimming and only running the 130 amp alternator with the power wire.
I know know that I could have done the same thing cheaper with rebuilt parts from the local parts store, but I'm happier with having the warranty and tech support.
I have bought the March pulleys, but have not yet installed them.
04sleeper
2,674
14
89
Dallas, TX
Oct 25, 2004
#12
  • Oct 25, 2004
  • #12
I have an overdrive pulley on mine. I would just switch it back if I had to return it. With the underdrive crank pulley and overdrive alternator pulley they kind of equal each other out.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 25, 2004
#13
  • Oct 25, 2004
  • #13
That is exactly like mine...but I have the March underdrives and my alternator can't keep up with all that...what could be the cause?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 25, 2004
#14
  • Oct 25, 2004
  • #14
What overdrive pulley do you have?
04sleeper
2,674
14
89
Dallas, TX
Oct 25, 2004
#15
  • Oct 25, 2004
  • #15
Auto Specialties.
Product Name: Alternator Pulley - 79-95 5.0 - 1 7/8" Alternator
Item #: ASP520004
Status: In Stock
Shipping Weight: 1.00 lb(s)
Price: $ 19.95
Pre-Tax Total: $ 19.95
http://www.aspracing.com/frame.htm
04sleeper
2,674
14
89
Dallas, TX
Oct 25, 2004
#16
  • Oct 25, 2004
  • #16
Summit has it a little cheaper.
http://store.summitracing.com/defau...10&Ntk=KeywordSearch&Ntt=overdrive+alternator
HISSIN50
34
129
Oct 25, 2004
#17
  • Oct 25, 2004
  • #17
with all the issues people have with low idle charging, why run an underdrive pulley on the alt at all? if running U/D's, i might run an OD pulley on the alt (how much parasitic loss, or should i say gain is there from running an U/D?). i doubt much (speaking for the alternator alone).
has anyone run a 4G alt?
Blandnuts
I don't swallow; I only swoosh
1,172
124
124
FloorDuh
Oct 25, 2004
#18
  • Oct 25, 2004
  • #18
I used some of the sites for "ideas" and an overall rough outlook on how to do the 3G upgrade. I did all the wiring myself without the kit and spent roughly 15 bucks. I had most of the little stuff (electrical tape, zip ties and some of the connectors). Overall, I think I spent a little less then 140...
If you want to do the wiring yourself, I just did this a month ago and did the hunt for all the parts so if you have questions let me know.
fred
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 25, 2004
#19
  • Oct 25, 2004
  • #19
So what kind of difference did you notice...so it bolts right up to a Sn95?...I thought the shafts were different on the (in my example) between the 93's and 95's...? Doesn't there need to be some sort of spacer?
I
Idwitheld-1`
335
Portland Oregon
Oct 25, 2004
#20
  • Oct 25, 2004
  • #20
Good Luck
I second that. 5sp GT is wiring retarded (j/k ) PA performance is awesome. Great products. Great service. I bought the 130amp with 4g wiring harness. The testing report that came with my alt. indicated like 90 amps at 900 rpm's...I mean cool!
1 of 2 Next Last
Electrical Alternator not charging after terminator 2 install.
  • Sfab79
  • Aug 24, 2025
  • 2 3
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
