which alternator did yall go with how many amp's and how much did it cost i just bought a set of UD - pullies and i have a stock alterantor and i wanna swap out the stock alternator would a 130 amp be to much?
ratrapp said:i bought a used 3ga (130 amp) for $40 and the paperformance wiring upgrade kit.i have around $100 tied up in mine.it still charges great even with my march u/d pullies.
I have an overdrive pulley on mine. I would just switch it back if I had to return it. With the underdrive crank pulley and overdrive alternator pulley they kind of equal each other out.5spd GT said:Does your lights dim at idle...mine does...I have the 130amp alternator with March underdrives also...I guess my only option to fix that is get an overdrive pulley for it...though it voids the warranty...
89roadster said:Anotherfor pa-performance. I have the black magic electric fan can run the head lights, wipers, defroster, and cd player all while idling for 30 minutes in traffic without lights ever dimming and only running the 130 amp alternator with the power wire.
I know know that I could have done the same thing cheaper with rebuilt parts from the local parts store, but I'm happier with having the warranty and tech support.
I have bought the March pulleys, but have not yet installed them.
89sleeper said:I have an overdrive pulley on mine. I would just switch it back if I had to return it. With the underdrive crank pulley and overdrive alternator pulley they kind of equal each other out.
Auto Specialties.5spd GT said:What overdrive pulley do you have?
89sleeper said:Summit has it a little cheaper.
http://store.summitracing.com/defau...10&Ntk=KeywordSearch&Ntt=overdrive+alternator
5spd GT said:Ah...we all get in hurry to type something...grammer errors happen...
Anyways I bought a 3g alternator from www.paperformance.com along with their "4g wire upgrade kit"...
The alternator and wire upgrade kit comes with full color instructions and I did the install pretty easily and I'm "wiring" retarded...
I bought the 130amp alternator though you can go bigger by getting 160 or 200amp Alts...
You will need to upgrade the fuse and some of the wires to bigger guages but everything I listed above (alt and wire upgrade kit from them) had everything I needed for the install...
It is one of the best mods you can do if you have things like a sound system, a/c, electric fan, etc...
Good Luck
) PA performance is awesome. Great products. Great service. I bought the 130amp with 4g wiring harness. The testing report that came with my alt. indicated like 90 amps at 900 rpm's...I mean cool!
