aluminum AFCO rad install`
twolo4u2c2
5 Year Member
Apr 10, 2003
330
reading, PA
It went fine. The hoses are no an issue. They slid right on with a little ATF(very light) I might add. The toughest part was the SS bracket I bought. It was a little short when reaching the thick core of the aluminum radiator. I notched the ends and added spacer so the core would sit tight. other than that it was a snap. took about 4 hours. It runs way cooler than before. I now can drive with the fan off..... before I had to keep it on at highway speed to keep cool. stop and go traffic was fine with the fan on and still stays around 180 or so.
Nice. Having a good radiator is so important especailly on a street car. I remember going from a stocker to a 3core copperbrass unit made a huge difference. Next I will get either an AFCO or Griffin.
The 31 X 19 does fit better. I put one in a buddys car and used the same stainless steel radiator bracket (Which I designed for UPR BTW) and it fit without cutting or adding brackets. I just had to reroute the wires that run right in front of the radiator around the front side of the core support so I could get the radiator to pull back a little more. It was tight but did fit.
Did you reroute your headlight and alternator wires?
ya I did that when I put the motor in. The only real thing was the width. I really should have gotten the 31". It would have fit much better.
