  • SN95 4.6L Mustang Tech
Aluminum driveshaft opinions
  • Thread starter Thread starter deftsound
  • Start date Start date Feb 1, 2008
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Feb 1, 2008
  • Feb 1, 2008
I am thinkingn about getting an aluminum driveshaft but have heard varying opinions on them.
First of all i have heard power gains are very minimal, making me question the point of getting one in the first place.
Secondly i heard they snap very easily with lots of power and sticky tires.
Discuss....
Smokeurhonda
457
Maryland
Feb 1, 2008
  • Feb 1, 2008
You won't feel any difference in performance, but if you have gears supposedly you will be rid of that annoying vibration. That's why I'm looking to get one. They are supposed to be stronger then stock, but that is debatable
scupking
1,186
Enfield, CT
Feb 1, 2008
  • Feb 1, 2008
I just bought one from American Muscle. It’s sitting in my room and I’m going to get it installed this month. They are stronger then stock and about 20 lbs lighter. Everyone says it reduces all the drive train vibrations from gears and helps acceleration.
spederman
732
  • Feb 1, 2008
i got one just for the hell of it. wasnt expecting much from it. but what it did end up doing for my car is making the clunking drivetrain 100x better. I dont get anywhere near the clunking sounds i used to. I did get a safety loop installed in case it does ever break though
faststang90
522
baytown texas
Feb 1, 2008
  • Feb 1, 2008
aluminum driveshaft
i had aluminum driveshaft on all my mustangs i have never had any problems from a 13 sec - to a 10 sec car. i have ran them on slicks to bfgs. im doing a bbf car and its going to run in to the 8 sec 1/4 my buddy had a drive shaft made he running a 408 with a powerglide engine shop told him to not use a aluminum driveshaft
joshheat25
871
Delaware
Feb 1, 2008
  • Feb 1, 2008
I had an aluminum driveshaft installed on my car. really helped out with the driveline vibrations. as far as sotp feel gains none what so ever. But technically it should increase power to the rear wheels! because of less rotating mass. Most likely very minimal.
yomadmike
55
Birmingham
Feb 1, 2008
  • Feb 1, 2008
Your right, kinda. The outside of the driveshaft is so close to the center of it's rotational force that any gain is minimal. Compare it to being on a merry go round. the closer to the center you get, the less pull you feel. So wether it's steel or aluminum, it's so close to the center. the torque gain is almost none.
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Feb 1, 2008
  • Feb 1, 2008
Don't get one if your expecting to feel power from it, because you won't notice any. I got one when I got my gears put in just because I heard it helps alot with driveline vibrations and so far so good
fobra559
At least it's more erect and not floppy anymore.
Nov 1, 2007
721
Lindsay, CA
Feb 3, 2008
  • Feb 3, 2008
Usually people get them with gears to solve the annoying vibrations. It's easier on your drivetrain and weighs less than the stock shaft which is good if you want weight reduction for the track. The revs seem to be smoother also, but not really any power gains. IMO, it's worth it in the long run, the FMS DS is the one I got and recommend
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Friday at 3:18 PM
2000xp8
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
