  • SN95 4.6L Mustang Tech
Aluminum Driveshaft
  • Thread starter Thread starter Stark77
  • Start date Start date Jun 30, 2008
Stark77
501
Tallahassee, FL
Jun 30, 2008
  • Jun 30, 2008
Taking the car in to swap out the rearend gears to 3.73's in my 01 automatic(I'm hoping it eat through the RPM's in the low end and still be good for highway use). Will there be any gain in performance from me picking up the Aluminum driveshaft for it and having them install that while they're opening up the rear end?
mogs01gt
3,113
30
119
Ohio
Jun 30, 2008
  • Jun 30, 2008
Not much if your car is pretty stock, it allows for quicker revs and less rotational mass.
CobraRed_96_GT
1,421
UCSD/La Jolla
Jun 30, 2008
  • Jun 30, 2008
Most (if not all) aluminum drive shafts are for manuals and are in that size. And i doubt you'll feel that much diff at all in an auto
Stark77
501
Tallahassee, FL
Jun 30, 2008
  • Jun 30, 2008
Auto should fit my trans/rearend as long as I use my own yoke - from what i've read. The shafts are actually the same length.
Flghtmstr1
572
Springfield, PA
Jun 30, 2008
  • Jun 30, 2008
I can confirm that the FRPP aluminum driveshaft will fit an automatic transmission-equipped car if the yokes are swapped. I can't tell you if it made a difference, since I did what you're asking about (I put it on the same time as the gear swap). It can't hurt, though
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jun 30, 2008
  • Jun 30, 2008
I bought mine when they were cheap. They now skyrocketed in price due to scrap going up.
Anyways. I didn't notice anything. My superchraged Cobra ran the same times at the track, I didn't feel a difference. So IMO, it was a waste of money.
96SCstang
228
novi, MI
Jun 30, 2008
  • Jun 30, 2008
they are a nice add on if you have the extra coin for one reason and one reason only. they take alot of centrifical force off the rear end bearings. being they are lighter they are way easier on them therefore helping your rearend last longer. no performance gains at all really.
Stark77
501
Tallahassee, FL
Jun 30, 2008
  • Jun 30, 2008
I'll spring for the extra $250 bucks for the driveshaft. I've heard it can drop 1/10 or 2/10 off the quarter mile. Any substantiation to this? Also, supposed to help out in xferring the engines power to the rear wheels (ie, reducing the drivetrain inefficiencies).
CobraRed_96_GT
1,421
UCSD/La Jolla
Jun 30, 2008
  • Jun 30, 2008
$250 isn't too bad, but i doubt that even if the D/S weighed 0 lbs it'd drop 2 tenths
joshheat25
871
Delaware
Jun 30, 2008
#10
  • Jun 30, 2008
  • #10
The Driveshaft will fit your car you just have to swap yokes. And as far as sotp feel there is virtually non with an aluminum driveshaft but it does smooth out virtually all driveline vibrations if you have any which you will if you install gears and imo you should get it along with gears to prevent further problems down the road. like me..
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
