I put alum. flywheel in when i replaced my clutch, some ppl are telling me it'll make me slower, I don't see how cuz my steel one was a heavy wildabeast compared to the aluminum
Test show that the flywheel is good for about .5 reduction in the 1/4 with a good driver. You do need to launch different due to the flywheel being lighter but if you can get it down you will see a reduction in E.T. Also the thing I like is with the steel if the tires break loose it revs up to the limiter (causing you to shift or let off), with the aluminum flywheel it revs up but grabs (tires gain traction) once again before bouncing off the limiter (at least mine does). Plus you can only resurface a steel so many times, it costs $75 to put a new steel insert in your aluminum one if you ever need to.
Fidanza makes some crappy cam gears for the 4.6L.
would the aluminum be useful in autoX?
twistedwankel
Not particularly as you have a rolling start and only shift once into 2nd gear. I also believe torque suffers greatly. Might be some benefit in faster engine braking due to less stored energy?
To me the only noticable benefit is the engine revs much faster is all. I wouldn't spend the money unless I was really into racing bigtime.
