Aluminum head advice
There is a guy on here who has run their heads and liked them, only complaints were the springs, which afr's are known to have not so good springs also, for the price they are probably worth it on a mild build but the afr's will most likely make more power.
If you have the money the afr165's would do good for you. I personally have no experiance with either head as I am going to be running twisted wedge heads or rhs 180's on my engine.
Put some on a friends car. We did the heads, TFS stage 1 cam, edelbrock intake, 65mm tb and 24# injectors. Car ran strong and sounded mean.
We lined up to my stock '03 GT and I beat it. :(
My old 89 had a TF stage one in it and I think it really hurt the performance of the car. On the dyno it was out of breath by 5K. Since I had GT40P's and all the right supporting hardware on it I have always suspected it was the cam.
I should have put we swapped off the 210cc version of those heads to the AFR205 and picked up 65HP. Like Dcurtis already posted the AFR165 or the The Twisted Wedge head would work very well for you.
dcurtis, the AFR spring issue has gone away with the newer designs.
