I need to get a new radiator so I figured I might as well get an aluminum one. I have a mild 289. Where can I get a good one for a reasonable price? Should I go with the aluminum one? If I get a 22 inch what changes will I have to make? Thanks!
blue66tang said:I would go with a northern, they are a direct bolt in and you wont have a single problem. There also cheaper then the high dollar name brand stuff. I have one for my built 289 and it runs nice and cool in 100 degree weather.
Mark66p said:I have even thought about going with the aluminum hose just cause it looks so much better. Well I guess I will order it, What about the bolts, did you have to change anything to bolt it onto your car?
norcalsvt said:I bought mine from mustangsplus. although if I remember right it was in the $500 range, not less. it's a griffin & that was easy to bolt on. not sure if this is overkill for you. My engine gets extremely hot since it's a 347 stroker
