(Not trying to Hi Jack, just trying to get answer to similar problem)I have an 03 with 22000 miles on it. It is having a similar problem, but I never even thought that it could be the actual oil Im using. Here is what my car is doing: When it is idleing every once in a while some smoke will come out of the tail pipes (just a little) and then it stops coming out, and then a few minutes later some more comes out, and so on. The other thing it does is when I shut the car down some smoke will come out of the pipes. I check the oil all the time and if it is burning it at a steady rate I cant tell. The level doesnt really seem to change. Also, as a test I started the car cold in the morning and then got out rite away to look and see if there was any smoke (If it smokes when you start after its been sitting that is an indication of worn valve seals) and there was none. So, Im wondering if it could be the oil (Mobil 1 (0-30)) Or something else like the PCV Valve. I never noticed the car doing this stuff when I was running Royal Purple 5-20 or the stock oil.
