am i shifting correctly?
gotchopsticks
315
i have an 02gt, with a tri-ax shifter, flows and O/R x-pipe. when i shift to second durring a race or just fooling around, i burnout enough to fishtail, on clean asphault. i figure that isnt good for racing, loosing traction and all, so i am wondering what tactics i should try to correct this. buying slicks, fatter tires or rims is out of the pic for a while. right now i am running Kuhmo 245/45/17. thanks
What RPM are you shifting at? The reason I ask is it sounds like you're shifting too soon, and are still more in the higher part of the torque band, and not the HP band. Look at a dyno chart, and that might make more sense. On a GT, if you're really good at power shifting, aim for 5500 RPM and see if the rear still kicks loose.
Jerry
my shift point is between 5500-5700. like i said before, slicks are out of the question because this is my daily driver, and i dont plan on taking it to the track anytime soon. should i not floor it when i shift? and im guessing it will be alot easier to break traction once i get my 4:10's, huh?
i am concerned because i like to go fast, and show up all the ricers in my town that think they are cool with the exhaust that sounds like a go-ped. the reason i dont want to go to a track is due to my location and transportation. and i beleive 4:10's will make my car more fun as well. but if anyone can answer my question about loosing traction, i would greatly appreciate it.
double clutch, or don't throw the clutch out extremely fast. If i ease it out in second, I have no traction problems even with 295s. But if i just thrash the gears, first second and third are basically non existent.
i feel extremly stupid asking, but what does it mean by double clutching? :bang: i think for me it would be kinds hard to ease while my adrenaline is pumping durring a race, and wouldnt that make yur shifting slower? i thought faster shifting was better durring racing :shrug:
The term "double clutching" doesn't refer to your problem here and isn't used in drag racing...
I didn't have traction problems in my 2000 GT and it still ran the same times as everyone else did...it would chirp second good but that was it...
Alot of things can determine traction problems: Type of pavement/wet/dry/tire or tire condition/gearing/suspension or condition of suspension/weight/etc...
I wouldn't powershift (holding down the gas during shifting) your car...the trans will last longer if you keep that to a minimum...
Yes the 410's will make it worse in the traction department...
Double clutching is a downshifting technique that promotes smoother transitions and lower transmission wear. It is useful for road racing, prolonging transmission life, and giving you an overall smoother ride.
first off, i dont power shift, everytime i depress the clutch, i let off the gas. but according to my friends, i shift the fastest out of them all. so am i doing everything correct? or should i just shift slower? thanks for everyones help :hail2:
