amp light on, no charge
bdub
67
kinston
the problem im having happened today as driving home from work, the amp light came on and the voltage dropped after driving really heavy. so i took the alternator off and got a new one, tested it, it was fine, and tested my battery. but the amp light is still on and the voltage wont come back up, anyone have any ideas of what could cause this?
Do all of these tests in sequence. Do not skip around. The results of each test depend on the results of the previous
tests for correct interpretation.
Alternator troubleshooting for 86-95 5.0 Mustangs:
Engine off, ignition off, battery fully charged.
1.) Look for 12 volts at the alternator output. No 12 volts and the dark green fuse link between the orange/black
wires and the battery side of the starter solenoid has open circuited.
3G alternator: Look for 12 volts at the stud on the back of the alternator where the 4 gauge power feed wire is bolted.
No voltage and the fuse for the 4 gauge power feed wire is open or there are some loose connections.
2.) Look for 12 volts on the yellow/white wire that is the power feed to the regulator. No 12 volts, and the fuse link
for the yellow/white wire has open circuited.
Engine off, ignition on, battery fully charged.
1.) Alternator warning light should glow. No glow, bulb has burned out or there is a break in the wiring between the
regulator plug and the dash. The warning light supplies an exciter voltage that tells the regulator to
turn on. There is a 500
ohm resistor in parallel with the warning light so that if the bulb burns out, the regulator still gets
the exciter voltage.
Disconnect the D connector with the 3 wires (yellow/white, white/black and green/red) from the voltage regulator.
Measure the voltage on the lt green/red wire. It should be 12 volts. No 12 volts and the wire is broken, or the 500 ohm
resistor and dash indicator lamp are bad. If the 12 volts is missing, replace the warning lamp. If after replacing the warning lamp,
the test fails again, the wiring between the warning lamp and the alternator is faulty. The warning lamp circuit is part of
the instrument panel and contains some connectors that may cause problems.
2.) Reconnect the D plug to the alternator
Probe the green/red wire from the rear of the connector and use the battery negative post as a ground. You should see
2.4-2.6 volts. No voltage and the previous tests passed, you have a failed regulator. This is an actual measurement taken
from a car with a working electrical system.
Engine on, Ignition on, battery fully charged:
battery voltage minus .25 to 1.0 volt. If the battery voltage measured across the battery is 15.25 volts, you should see 14.50 volts
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
I know this sounds redneck but rev it up real good a couple of times. Sometimes this excites the stator. I had to do that once and the alt charged ever since. I might of just got lucky too.
1.) Have the entire car's charging system tested. Most major
auto parts stores will do this for free.
2.) Have your battery trickle charged for 2 days or so. This will
often fix the low charge problems that don't seem to have any bad parts.
3.) The secondary power ground is between the back of the
intake manifold and the driver's side firewall. It is often missing or
loose. It supplies ground for the alternator, A/C compressor
clutch and other electrical accessories such as the gauges.
Any car that has a 3G or high output current alternator needs
a 4 gauge ground wire running from the block to the chassis
ground where the battery pigtail ground connects.
The 3G has a 130 amp capacity, so you wire the power side
with 4 gauge wire. It stands to reason that the ground side
handles just a much current, so it needs to be 4 gauge too.
The picture shows the common ground point for the battery & alternator
Picture courtesy timewarped1972
I read this post yesterday as it looked very helpful in my problem with my '89 'stang with a 3g conversion.
Everything's been functioning fine for a year now and then just yesterday the battery light came on the dash. So, I followed your steps this evening and everything checked out until the last step, which you don't mention what the issue is.
Your last step:
Engine On, Ignition On, Battery full - probe the red/green wire from the rear of the connector and use the battery negative post as a ground. You should see battery voltage minus .25 to 1.0v.
My result was I saw 2.74v when I ran this test (battery voltage was 14.86v), but when I ran the previous test, probing the same wire with the engine off, I was within range with a reading of 2.45.
So, what does it mean that I failed that last step? Does it still mean my regulator is bad?
Thanks for any assistance you can provide.
