  • Mustang Sound & Shine All
amplifier question
  • Thread starter Thread starter 03 Black GT
  • Start date Start date Dec 30, 2005
03 Black GT
117
Atlanta
Dec 30, 2005
  • Dec 30, 2005
I have a pair of subs (10" fosgate T1's 4 ohm) that are about 600 watts rms each. A guy at a local audio shop said that a 2 channel rockford T3002 amp would be perfect. The amp specs say it can handle 300 watts max. When I asked about if it could power the subs good enough, he told me they would bridge the amp.
What exactly is bridging an amp and will this combination work as he says?
04gtboy
83
  • Dec 30, 2005
use one channels positive and the others negitive but ur amp must be able to handle it or it will overheat id say it will being a fosgate
03 Black GT
117
Atlanta
Dec 31, 2005
  • Dec 31, 2005
wait, are you saying it can handle it b/c it's a fosgate, or it will overheat?
03 Black GT
117
Atlanta
Jan 2, 2006
  • Jan 2, 2006
bump, anyone else ?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jan 2, 2006
  • Jan 2, 2006
check the fosgate website, it should say in the specs of the amp if its bridgeable
DocG
5th graders > me. They're not bant
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Jan 2, 2006
  • Jan 2, 2006
Need more info about your amp. What is the range of your speaker power...it says 600 watts rms...but usually there's a range and you want the amp to match about midway in the range at least. In your case, 50% of the max is probably close enough, so 300 watts rms from the amp to each speaker.
Is that 300 watts max power to each channel? If so, bridging your amp is like he said above...you wire both speakers in parallel to the positive of one channel and negative of the other...the instructions of your amp should describe it. Make sure the amp is 2 ohm stable. With 2 4ohm subs, you amp will see a 2 ohm load. If you bridge it and its not an amp set up to be bridged, it will probably end up seeing a 1 ohm load since you're halfing the load once by wiring the speakers in parallel and again by bridging the amp. But it will at least double the power output of your amp, but then again its powering 2 speakers.
So anyways, I have a 200 watt mono Fosgate running 2 12's....bridged....and it pounds, so I"m sure you'll be fine. Fosgate amps are really strong. Besides if the salesguy says it will sound good, and it doesn't, tell him you want your money back!
DocG
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Jan 2, 2006
  • Jan 2, 2006
http://www.rockfordfosgate.com/prod...temKey=10065615&CategoryDesc=Power Amplifiers
I just checked their site...the amp is 1ohm stable and bridgeable....bridged power to 1 channel to a 2ohm load is 300 watts...probably plenty of power.
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Jan 2, 2006
  • Jan 2, 2006
Moved to sound shop and to hopefully get you more information.
W
WillDuhhBeast
339
Jacksonville Florida
Jan 2, 2006
  • Jan 2, 2006
I'm not sure about new RF stuff, but the older amps were some fo the best. As for the guy that said "it could over heat" thats bull. It will heat normally, amps get hot.. but I dont think you'll have to worry about it over heating. Naturally, dont put it VERY close to your rear seats or anything like that and you'll be just fine.
The guy at the shop is right, and he's saving you a load on an amp but telling you to go this way. If you're budget can handle more, then there are better options out there.
This way will work, and it will save you money.
Run a 5 channel or use head unit and mono amp for sub?
  • 2000xp8
  • Sep 20, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2024
2000xp8
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
SOLD 1993 Mustang LX Notchback- 347 Stroker
  • Bzammitt
  • Jun 19, 2021
6K
Fox Body Mustangs For Sale (1979-93) Jul 10, 2021
Bzammitt
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
20K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
Exhaust Headers - Myths and Secrets...
  • geoklass
  • Jun 20, 2020
5K
Fox 5.0 Mustang Tech Nov 9, 2021
WhiteCobra95
