An Audio Question.
  • Thread starter Thread starter hoopty5.0
  • Start date Start date Feb 3, 2015
hoopty5.0
mechanicus terribilis
7,852
6,994
214
SW Houston
Feb 3, 2015
  • Feb 3, 2015
I ran the wires for my audio system a few months ago when I did the sound deadener. Last night, I put the 10" woofer and amp in the trunk. I am waiting to get the harness adapter in the mail for the head unit, but in the mean time, my question is can I run the door and dash speakers off the head unit through the factory harness and the rear 6x8s and sub off the amp? Will this cause any issues? The system is not meant to blow eardrums by any means, just an upgrade from stock. The door and rear speakers have been upgraded to some decent Pioneer units, also.
Might have to drag @LaserSVT up from the depths of the SW on this one.
LaserSVT
3,548
233
Feb 3, 2015
  • Feb 3, 2015
Yes
FoxMustangLvr
I love my Pimp
SN Certified Technician
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Feb 3, 2015
  • Feb 3, 2015
There's no problem doing this but don't expect great sound quality until you install the aftermarket head unit.
hoopty5.0
7,852
6,994
214
SW Houston
Feb 3, 2015
  • Feb 3, 2015
Nothing is hooked up yet, still waiting on the adapter harness. 100% stock audio until then.
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Feb 3, 2015
  • Feb 3, 2015
I think I misunderstood. I thought you were going to run the pioneers of the stock HU until the adapter harness came in. It's not a big deal, speakers always sound better through an amplifier. Quality HU's typically have 35-45Wx4ch true RMS and can cleanly power a 5" or less speakers no problem. Be careful, the 6x8s can easily over power the other speakers. I would run the 6x8s on a lower frequency (but not the lowest) that should be adjustable on your amp.
7991LXnSHO
wanna catch the space herp
7,387
2,746
194
Kearney, NE
Feb 3, 2015
  • Feb 3, 2015
On a lower frequency????
So are you talking about running a low pass type filter? That would make them like subs? Or do you mean to run them at a lower power level at full frequency range?
hoopty5.0
7,852
6,994
214
SW Houston
Feb 3, 2015
  • Feb 3, 2015
No, I have no way to hook up the amp until I get the harness. Assuming the 6x8s are too loud, I can always adjust the fade, correct?
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Feb 3, 2015
  • Feb 3, 2015
Most amps will have a frequency adjuster on it that you can select a low, med or high frequency for the speakers you're running. The lowest is only for subs 8" or larger, the mid freq are suitable for larger mids about 6", 5x7, 6x9 etc, then the high freq would be best for coaxial 5" all the way down to tweeters. Most quality 2 or 3 way oval speakers have a built in HPF so the tweeters won't distort and also you don't want any high frequency running through the larger oval speaker, only mid-low freq. This will help tame the speakers down a little and give you good mid base if you listen to music like rock, metal or punk. If it's still too much you can simply use your fade. This is how I've always ran my stereo systems especially when I don't have a sub. The best systems for me have been without a sub, or if I had a sub it was a 10" JL W3 dual voice coil in a sealed box. I listen to Rage against the machine, slipknot, Pantera, suicidal tendecies etc and punk so It's important for me to get the mid range frequency dialed in so I can hear the bass guitar in Korn, the toms getting drilled by Joey Jordison, the kick drum in Rage, etc.
Sorry it's a long response.
Reactions: hoopty5.0
hoopty5.0
7,852
6,994
214
SW Houston
Feb 3, 2015
  • Feb 3, 2015
That's great info, and exactly what I was looking for. Thanks!
hoopty5.0
7,852
6,994
214
SW Houston
Feb 3, 2015
#10
  • Feb 3, 2015
  • #10
The Amp has 4 channels, so i can definitely run the 6x8s and the sub independently. Will definitely be coming in here with more questions. There's a lot of buttons and switches that I have no idea what they do, lol.
Radio, Speaker Upgrades
  • TripleYellow
  • Apr 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2026
TripleYellow
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Run a 5 channel or use head unit and mono amp for sub?
  • 2000xp8
  • Sep 20, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2024
2000xp8
Stereo snakes nest; what am I missing?
  • Scott_S
  • Aug 29, 2025
  • Mustang Sound & Shine All
Mustang Sound & Shine All Sep 24, 2025
Scott_S
T
Need advice: 93 Cobra audio upgrade with no permanent modifications
  • THNX SVT
  • Feb 18, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2024
TIGGER
