Analyze my combo
  • Thread starter Thread starter sunil6784
  • Start date Start date Jan 17, 2006
sunil6784
620
Boston, MA
Jan 17, 2006
  • Jan 17, 2006
New 302 block, bored .030 over.
Eagle Racing 331 stroker kit w/ steel crank (http://store.summitracing.com/partd...4294919598+4294854588+4294832635&autoview=sku)
Victor Jr. Heads
Victor Jr. intake
Custom Cam
I have a few questions, this stroker kit says it is not balanced. If I get it balanced from the machine shop, is it more expensive then spending the 700 more for it to come pre-balanced? Also, I was thinking of going to 30 pound injectors, is this enough?
M
mikemustang289
224
mesa, az
Jan 17, 2006
  • Jan 17, 2006
the only way to balance it correctly is with the flywheel/clutch and balancer that you plan on using.
Machine shops typically charge $200 for a dynamic balance. you will need the rods, pistons, and bearings you plan on using as well.
The cost can go up depending on how much malory metal they need to add to the crank counterweights.
I would definitely take it to a reputable machine shop with all of your parts. A flywheel and balancer can throw the assembly out of balance if they are not balanced together. I would assemble everything first and check all your clearances. If it checks out ok then take everything apart and bring it to the shop for balance.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Jan 17, 2006
  • Jan 17, 2006
Find a good shop and see what they can do for you before buying anything or making any decision. My guy had excellent products available and better than I had found prices...all together he saved me a good chunk of change, and built me a solid shortblock.
  • Locked
1989 Mustang GT built street/strip w/pics
  • redhot89
  • Apr 3, 2012
7K
Fox Body Mustangs For Sale (1979-93) May 17, 2012
nicknjayme
N
  • Locked
Sbf High End Parts For Sale
  • 304billet
  • May 25, 2012
  • Engine and Power Adder
2K
Engine and Power Adder May 25, 2012
304billet
  • Locked
Fox Body Ready 393 Stroker with Conversion Headers and Pan
  • kikz19
  • Dec 5, 2011
3K
Engine and Power Adder Dec 5, 2011
kikz19
M
Need a new starter.. What's good.
  • MYSC351
  • Apr 20, 2009
3K
Fox 5.0 Mustang Tech Apr 21, 2009
jrichker
L
  • Locked
SHOW CAR!! ...1988 Mustang LX-49K MILES(331 Stroker/TKO600/31 Spline/Willwood) TX
  • LS3vette
  • Nov 13, 2011
8K
Fox Body Mustangs For Sale (1979-93) Dec 25, 2011
pack018
P
