and it just gets better and better.
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
now the **** slinger wont start.
i think the starter is fried. it wont even click and i believe the sylonid(spelling?) is far gone.
:mad:
im starting to really regret buying a 23 year old car.
bynummustang said:
The car is 10 years older than you!!!! :rlaugh: hahahahhahahah
Just a reason to get a mini starter. You'll learn that when stock stuff breaks, till to replace it with something better. That being said, hold the car at 12,000 RPM for 4 minutes.
tis just keeps costing me and costing me. bought it becasue of very low miles.
and it runs worse then my dads mustang with over 230,000 miles in it :mad:
GT89Mustang said:
:D Just messing with you. Our cars are old, even if they have low milage just sitting around can deterate(sp?) stuff. Its a never ending battle.
yeah. il be glad when i can sell this and buy a V8 or put a V8 in it. just takes time.
i think i found the problem.................
when i crawled in i hit the gear shift in R somehow. when my dad gets back i will try to start it and see what happen.
i hope that is just it. if it is boy do i fell like an idiot.
:lol:
ps: checked the fuses did find one that was bad.
Hardest part is getting the auto out and putting the manual petals in. BTW my car is 27yrs old and has never left me stranded or refused to start. Dont blame the age of the car, blame the skill of the mechanic.
A lot of times, but not always cars with high mileage are more reliable, because most of the stuff that will wear out soon or that has deteriorated on a low mileage car has already been replaced on the high mileage one.
Or I replaced everything that was old before it went bad. When I bought my car 5 years ago everything was original down to the plug wires. Then When I put another high mileage but great running engine in it, it also had to original plug wires, I replaced all the normal maintinence items on that engine too.
The hardest part of the t-5 swap is taking the auto trans out. The pedal assembly is easy took me liek 30 minutes when i did it. Its just getting that dam aod un hooked and out from under the car..
foxstang9050 said:
My advice when pulling out the aod.... have a punching bag handy... saves alot of knuckle marks on the car and garage walls... and make sure you have the extensions to get the two top bellhousing bolts out... other than that its cake
Hahaha werd when i did my swap i threw a ratchet and a 12mm combo wrench through the wall of my garage..
