Hey, I just bought an '88 GT and discovered that the dash lights (speedo, tach, heater/ac) are not working. Coincidentally, the speedometer is not working at all?
I've read the archives about checking the fuses and that it is probably the dimmer switch.
Question- What needs to be removed in order to change the dimmer switch?
Also- If the dimmer doesn't fix the problem, will I have to pull the instrument cluster out for any reason?
Any advice is truly appreciated.
Jeremy
Jeremy
