anderson n-412 cam. anyone have any specs or info?
cenok is family
1,409
69
79
Norman, Ok
well i purchased a cam off of ebay that was advertised as an afm n-41 cam. i got the cam in and it looks great, but it has n-412 engraved on it. i looked it up on their website and it looks to be pretty dang close to the n-41, but a change in some of the wording they used in its description lead me to believe it's a tad bit smaller of a cam than the n-41. the powerband seems to be a bit lower. anyone know the specs on it? i've looked everywhere and haven't found anything. here's what their website says about the N-41 and N-412:
N-41
302 c.i.d. This cam is to be used with 1.6 R.R. Best cam for GT-40. Great with TFS or Edelbrock heads. Minimum 24lb injectors and 75mm mass air. Recommend 3.73 to 4.30 gears. Good drivability down to 2100 rpm, lumpy idle, rpm range 2600-6200, works best with 89-93 EEC, needs 2800-3000 converter.
N-412
302 c.i.d. This cam is to be used with 1.6 R.R. Great with GT-40, TFS or Edelbrock heads. Minimum 24lb injectors and 75mm mass air. Recommend 3.55 to 4.10 gears. Great drivability down to 1800 rpm, nice idle, rpm range 2300-6200, works best with 89-93 EEC, needs 2500-2700 converter.
From my link in my signature:
AFM N-41 - 222*/232* - 278*/286* - .512"/.512" - .320"/.320" - 110* - 106*/114*
Overlap: 62 degrees.
1.6 Rocker Ratio
Intake Opening: 1* BTDC
Intake Closing: 41* ABDC
Exhaust Opening: 45* BBDC
Exhaust Closing: 5* BTDC
