Another 5 Lug Question, Do the Fox Softlines Fit SN95 Calipers?
Starscream88
1,277
Park Ridge NJ
As the title says
Just 100% checking
I have SN95 Banjo bolts,
and Ive "heard" that Fox Softlines work,
Now, Is this 100% true?
Its just a straight bolt on? Or modifiacation nessasary?
Also Witht the rear discs, I have the Adjustable Prop Valve,
Where do I set it at? :confused:
How many turns?
I'd heard the same thing, but when I went to do mine, they weren't even close ('97 calipers/spindles onto a '93). I ended up just getting nice new stainless lines from maximum motorsports. Good luck.
Jamie,
I've heard that you can grind them too, but the only thing I found was this bit on Matt's website about the 99+ calipers:
The '99+ brake lines that come with the caliper are not direct bolt-ins for the 79-93 cars at the hard lines. If the passenger side line does not work, you need to an adapter to bolt them on. The stock 87-93 v8 brake lines have a lip on them to keep them from rotating on the caliper. That would have to be ground off to use it with the PBR calipers and grind the caliper a bit to make them work. I would suggest to not ue the stock brake lines and upgrade to the '99+ Mustang units or aftermarket SS lines. If you are going to upgrade, most SS lines use a round piece at the caliper end, so you will not have mounting issues on the caliper.
More info on the grinding:
http://home.flash.net/~rfm2/pbrdual.htm
Regarding the PV, from Matt's website again, you turn it all the way in to bleed the brakes, and then all the way out and then in like 3 or 4 times for the initial setting, then fine tune it from there.
You just need to READ MAtt's website again! LOL!
Thomas
Yeah Ive read Matts website so bloody much,
Hmm, I did just have a set of SN95 Softlines that i took back to the parts store,
Mabey Ill go buy them again, Saves the BS'ing around come this weekend
So the Stock lines DO have to be modified right? Im using 95 Calipers
Unless you have replaced your lines recently, like in the past 4 or 5 years, I would just go ahead and get new lines for safety's and performance sake. Mine were so bad when I replace my brakes I'm surprised they didn't spring a leak! No sense risking damage to that new paint job with old worn brake lines.
I am in the proess of puttine 00 stuf on my car, and the the driverside 00 line bolted right up to the hardlines(89 stuff). The paasenger side is different at the soft to hard line connection. You can use you Fox body soft line with SN95 banjo bolts if you grind the block where the banjo bolts goes through to fit the sn95 caliper. I was gonna do that, but eneded uop getting Russell braided lines..
