Another 9" question
  • Thread starter Thread starter crzipilot
  • Start date Start date Sep 27, 2007
C
crzipilot
51
Sarasota, Fl
Sep 27, 2007
  • Sep 27, 2007
I've read most of the write ups and such, but can anyone tell me for sure/definative A 1975 Grenada 9", is it a direct bolt in to a '65??? Except for the Ubolts?
thanks
ratio411
3,870
73
109
Pensacola FL
Sep 27, 2007
  • Sep 27, 2007
Yes.
Depending on the rear your car came with, you may need a hybrid rear u-joint.
ultrastang
1,092
Arkansas
Sep 27, 2007
  • Sep 27, 2007
thanks
Is this a Granada 9-inch disc brake rear end (same thing as Versailles rear end), or is it a Granada 9-inch drum brake rear end?
If it's a disc brake rear end, you'll need U-bolts to fit around a 3" axle tube. If it's a drum brake rear end, you'll need U-bolts to fit around a 2-3/4" axle tube. You would also have to modify your original spring plates for the appropriate U-bolt spacing. This is best done by welding the original holes up solid and drilling new ones to fit the needed U-bolts.
On a Granada 9-inch disc brake rear end, it will have a round companion flange where the driveshaft bolts up. This will have to be removed and replaced with a 1310 or 1330-series companion flange designed for a conventional U-joint.
On the Granada 9-inch drum brake rear end, it will have a conventional companion flange, but it MAY be too long to use with your stock-length driveshaft. If it is, you will either have to shorten the driveshaft, or you could get a shorter companion flange off a '65-'85 Ford half ton pickup. The latter would keep you from having to shorten the shaft.
C
crzipilot
51
Sarasota, Fl
Sep 27, 2007
  • Sep 27, 2007
Great info guys....thanks a bunch...
D
D.Hearne
11,730
south louisiana
Sep 27, 2007
  • Sep 27, 2007
Instead of changing the U bolt plates, replace them with a set of Lakewood traction bars. The flange(if it's what I'm thinking it is) can be mated with one from a 90's Ranger, then use the appropriate U joint to fit the driveshaft.
ratio411
3,870
73
109
Pensacola FL
Sep 27, 2007
  • Sep 27, 2007
Why not just use spring plates and u-bolts from the Granada???
That is what I would try.
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
A
90 Fox 4Lug rear convert to 5 Lug
  • adimice
  • Jun 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
limp
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
