Another auto to 5 speed conversion question
Hey guys , im wanting t o swap out my auto c4 for a 5 speed in my 67 mustang coupe with my 302... i know this has been asked many times.. but im at work and dont have but a few minutes. any one know what trany will fit the best and for the best price. what yrs should i look for and so on for the trany? also what all is needed for the swap. what pedels shoudl i get ahold of
see my signature...
As for the pedals- are you going to use power brakes? If so then are you going to use an aftermaket booster or the real bendix or midland unit. These things are important for the swap. For example: if you use an aftermarket booster it wil not fit the JMC Hydralic kit and will have trouble with the modern driveline unit as well.
You can allways purchase the new brake pedal from John's Mustang and a clutch pedal used to do the swap. Some support brackets have the holes for the power brake pedal and some do not so check under the dash to see if your bracket has the hole or not.
If you can afford it Buy a new T5 from Jegs. It is a lot stronger and you know you are getting a real V8 T5.
