Another Clutch Cable Problem
  • Thread starter Thread starter Brando5641
  • Start date Start date Oct 3, 2009
First Prev 2 of 2
HISSIN50
34
129
Oct 15, 2009
#21
  • Oct 15, 2009
  • #21
Talk to MM. You should not need a spacer (in effect, making your FWA 'longer'). Something isn't right on your car and they might have some ideas.
Brando5641
127
FT Gibson OK.
Oct 16, 2009
#22
  • Oct 16, 2009
  • #22
Its not the car. It has new flywheel,clutch,TOB,fork,steel retainer,new tranny.
HISSIN50
34
129
Oct 16, 2009
#23
  • Oct 16, 2009
  • #23
Is it a stock replacement fork?
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Oct 16, 2009
#24
  • Oct 16, 2009
  • #24
I'm thinking it's your quad. Not all aftermarket clutch quadrants are made with the same dimensions. It might be allowing for too much slack - more than your FWA can allow you to dial out. Maybe look into getting a different quad from Maximum Motorsports, or UPR.
HISSIN50
34
129
Oct 16, 2009
#25
  • Oct 16, 2009
  • #25
Since it's a kit, that should be the most optimal quadrant there is for that cable.
Brando5641
127
FT Gibson OK.
Oct 17, 2009
#26
  • Oct 17, 2009
  • #26
It is a dorman fork,oreilly fly and clutch,also the best TOB they have and a steel bearing retainer from Hanlon Ms.
Posted via Mobile Device
HISSIN50
34
129
Oct 17, 2009
#27
  • Oct 17, 2009
  • #27
How did the fork compare to the stocker when held side by side?
Brando5641
127
FT Gibson OK.
Oct 17, 2009
#28
  • Oct 17, 2009
  • #28
it looked the same.
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,118
224
Massachusetts
Oct 17, 2009
#29
  • Oct 17, 2009
  • #29
I bought the Ford kit for $50 that comes with the cable and a new clutch fork.
Granted, i've onl driven 600 miles on it though...
First Prev 2 of 2
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Drivetrain Time to pull and lube the clutch cable
  • LX Dave
  • Dec 21, 2024
2K
Fox 5.0 Mustang Tech Jan 7, 2025
limp
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
