Another Clutch Question...
  • Thread starter Thread starter BlackBullitt14
  • Start date Start date Aug 23, 2014
BlackBullitt14
Little Rock, AR
Aug 23, 2014
  • Aug 23, 2014
Hey everybody, thanks in advance for your input.
I just had installed a RAM HDX clutch with a new RAM billet steel flywheel on my '01 Bullitt. I've been driving it about a week and taking it easy to break it in right. Besides the stiff pedal feel, I was surprised how close to the top of the pedal I was before the clutch engaged. Almost stalling one time using reverse. I have also noticed chatter mostly at lower RPM's. Is the clutch engagement point and chatter going to improve once broken in? It's a Stage 1 clutch kit and just a step up above OE. My car's putting out about 325HP. Need more horses?
Thanks again.
flstang65
1,484
135
94
SE Georgia
Aug 23, 2014
  • Aug 23, 2014
You qould have been fine with an OEM clutch but, you are fine with what you have.
silversmith82
67
Aug 26, 2014
  • Aug 26, 2014
Make sure the preload on your clutch cable is correct and that you are using an OEM cable. If you had a shop do the install they might have gotten the cable too tight. If you have a multi-hook quadrant that can also change the engagement point as far as where your foot placement is. I just did an Exedy Mach 400 clutch on the 16th and it starts to engage almost immediately after my foot comes off the floor. I run an OEM cable, with a Max Motorsports quadrant and have the preload set correctly with a fiore microclick firewall adjuster.
TeamCaffeineGT
193
15
18
Springfield, MO
Aug 27, 2014
  • Aug 27, 2014
The stock clutch quadrants are said to be weak units. Perhaps the quadrant is the issue. As silversmith82 mentioned, it could just need adjustment. The easiest way to do this if you have a stock quadrant is to simply pull up on the pedal. It has a self adjusting mechanism that should click when taking the slack out of the cable. If the cable is adjusted manually and is too tight, you will notice as the clutch will not fully engage.
H
Drivetrain 4R70W clutch friction/metals/piston set up questions for transmission guru
  • Hizdudeness
  • Apr 4, 2024
Fox 5.0 Mustang Tech Nov 15, 2024
slow84lx
Should I Get a New Clutch Fork and Pivot Ball Stud?
  • AeroCoupe
  • Dec 18, 2022
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 21, 2022
96pushrod
Drivetrain New Ram Clutch and G Force gear set cable tension concerns.
  • skiwesser11
  • Oct 16, 2021
Fox 5.0 Mustang Tech Oct 20, 2021
Dan02gt
Could not pass this up .. guess the AOD is out
  • mikestang63
  • Jun 1, 2021
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 7, 2024
FastDriver
C
Clutch opinions?
  • ClayBelt
  • Jul 3, 2020
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 5, 2020
ClayBelt
C
