another cooling question
  • Thread starter Thread starter kidtaurus
  • Start date Start date Jul 5, 2004
kidtaurus
221
Athens, Ga.
Jul 5, 2004
  • Jul 5, 2004
What press. do u recommend that I get when I go to buy a new radiator cap. I have seen a griffen 14-16 and a howe 22-24, and moroso has a 19-21,23-25 and a 27-29lb.
HistoricMustang
2,359
Confederate States of America
Jul 5, 2004
  • Jul 5, 2004
The 14 - 16 will work fine for street use.
HistoricMustang
www.historicmustang.com
kidtaurus
221
Athens, Ga.
Jul 5, 2004
  • Jul 5, 2004
Is there advantages/disadvantages of going higher?
kidtaurus
221
Athens, Ga.
Jul 5, 2004
  • Jul 5, 2004
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Jul 5, 2004
  • Jul 5, 2004
the advantage is you can run hotter without overheating, the disadvantage is you can blow your radiator rom too much pressure. 14-16 is fine
Restomod 67
125
Quebec, Canada
Jul 5, 2004
  • Jul 5, 2004
When you raise the pressure it also raise the boiling point of your coolant, it won't cool the engine better, just raise the boiling point.
Route666
1,652
Brisbane, Australia
Jul 5, 2004
  • Jul 5, 2004
Raising the boiling point though, in turn, will allow the coolant to stay un-airated, and hotter. A higher difference between a hot object and the surrounding environment temperature means a higher rate of cooling, or heat transfer anyway. With a radiator, you can assume surrounding env. temp. does not increase as heat is transfered from the radiator to the air, as new air is introduced as you drive along.
What this means is that if you have two radiators, both flowing the same amount of water and air, with air at the same temperature, and one has hotter water flowing into it, the hotter one will cool at a faster rate.
That isn't to say the hotter one will cool the engine to a lower temp., it will most likely still be a tiny bit higher than the lower temp. water one, BUT, the system is capable of taking more heat out.
What it means to cars: You can cool more horsepower with a higher radiator pressure.
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • dan50
  • Jul 18, 2026
dan50
V
Cooling fan low speed not turning on
  • vman
  • Feb 27, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 24, 2025
vman
V
