Another disc brake conversion ?...
  • Thread starter Thread starter dlucas4134
  • Start date Start date Aug 20, 2008
dlucas4134
SC
Aug 20, 2008
  • Aug 20, 2008
I've done all the necessaries for a 5 lug/ rear disc fox. The brakes are better. However, I have a hard pedal now. Seems like I read somewhere (here maybe) that a different booster will work better than the original 93. I'm using a 95 Cobra m/c with a Maximum Motorsports m/c adapter and prop valve. Can someone tell what booster I should use with setup? I was thinking 94-95 v6, but will this work with the Cobra m/c?
tia
dlucas
93 LX
3,081
Norwalk, CA.
Aug 20, 2008
  • Aug 20, 2008
you need a cobra Booster however its a beast to get it in.. I guess you could try hydroboost.
Nova
128
  • Aug 21, 2008
you can use a 93 cobra booster, or a 94/95 booster. the 93 cobra is the smaller of the two. you might have to elongate the holes slightly to get it to slide in place.
i did it in an evening with a helper.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Brakes Sealant for passenger side brake line fitting? (Weatherhead 7828)
  • dan50
  • Nov 9, 2025
Fox 5.0 Mustang Tech Nov 12, 2025
dan50
