another dumb clutch question
jmd2914
937
Napa, California
alright, i just ran my cluch cable through the hole in the bellhousing so i can attatch it again, how tight do i make it? there is alot of slack right now do i just twist the nuts up more till there isnt that much slack?
I would set it so there is no slack for right now and see where the point of engagement is. You dont want to preload a new clutch too much.
The second nut is just a locknut for once the clutch is adjusted where you want it.
Good luck.
with the adjustible clutch cable, get rid of the slack and use the firewall adjuster the rest of the time. make sure yu dont fine tune the clutch til after the break in cycle. usually 500miles or more
