Another Fog Light Question
  • Thread starter Thread starter dom1410
  • Start date Start date Mar 26, 2007
D
dom1410
  • Mar 26, 2007
I saw this thread on cutting a prong off the relay but it wasn't really clear. Will this permanetly keep the fog lights on or will it work with parking light then? Otherwise I will be doing the Corralnet fix. Is this good for all years I have a 95 Mustang GT Convertible.
Blackened302
1,439
South TX
Mar 26, 2007
  • Mar 26, 2007
i myself went w/ the MustangWorld How-to (in which you take power from the convertible top harness) and am very pleased w/ the results. i've ran them this way for close to a year now and haven't had any trouble whatsoever.
94-302-vert
1,947
NE CT
Mar 26, 2007
  • Mar 26, 2007
I tapped mine right off my guage lights.... they come on whenever the parking lights are on.
HISSIN50
34
129
Mar 26, 2007
  • Mar 26, 2007
I also did the vert top method. With this method, the fogs can only be on when the key is on. You could do the same method but use the parking light circuit as the switch source (fogs would only come on with parking or headlights).
Good luck.
D
dom1410
  • Mar 26, 2007
Could someone give me the link or specific instructions to wire into the parking lights. I want the for lights attached and controlled by parking lights I don't want them on whenever the car is running.
HISSIN50
34
129
Mar 26, 2007
  • Mar 26, 2007
The simplest way to explain would be to access the headlight switch and tap in there. It's a brown wire for the parking lights IIRC. Run this new wire (18 AWG is fine) to the fog light switch and insert this wire where the old power wire used to be on the foglight switch connector.
Good luck.
trav_19
810
Jackson, MI
Mar 26, 2007
  • Mar 26, 2007
lol tapping off the vert switch dosent make them stay on all the time.... it is just like your lights are now but you can turn the fogs on whenever you like.... its the method i used and i couldn't be happier
D
dom1410
  • Mar 26, 2007
What color is the power wire leading to the fog light switch and vert switch?
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Garage Lighting
  • gkomo
  • Oct 20, 2025
  • Off-Topic Hangout
Off-Topic Hangout Nov 29, 2025
Clutchfork
A
95 GT parking brake instrument cluster light trouble
  • Aroenias
  • Jun 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2025
Mustang5L5
J
Fox 1986 V6 Fuel/Electrical Issues, crank, no start, turns over with starting fluid
  • JlChamberlain
  • May 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2025
gkomo
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
