Another idle problem question with a twist..
KENS89LX
302
Cross lanes Wv
I'm sure this question has been on here many times its for my cousins 87 gt which has been converted over to mass air, the prob is that it won't idle when the engine is cold after it warms up its fine, he has changed the IAC, tps, mass air meter, the temp switch on the intake, now the thing is the engone light does'nt work so he can't pull codes, any ideas?
So it doesn't perform well in open loop. It could be many things, but most likley your problem will have to do with fuel delivery. Crank the car, when it starts to do this, shut down and check a plug. If the plug is wet, or a lot of black then you are probally running rich, if "clean" or white, your probally running lean. What calibration is the MAF and what injectors? The oxygen sensors will for the most part correct, but when the motor is cold, they arn't working yet.
And he should be able to pull codes. See JRichker's post about doing so.
Did anyone check the ECT (I have no idea what was referred to in the opening post)?
Good luck.
Help in the pulling codes department...
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Wal-Mart may now have the LCD display scanner for less than $35
I had the exact same problem as you after my Mass air conversion. I raised the idle speed up a bit (to about 850-900 RPM) and advanced the timing a bit. After that, it ran like a champ.
EDIT: There were no faults stored in my case.
