Another Oil Change Question Xd
10W-30, about 5 quarts. Definitely change your rear main seal if you have the clutch out.
Kurt
Do up the pilot shaft bearing as well while its open.... they're cheap. Some kits come with em anyway.
I was watching a video on the rear main seal and they were saying something about a sleeve and then a little tool so it hammers in evenly? do I need that stuff? where to get?
and for the pilot bearing i noticed there was grease inside when i took it out? do i need to regrease that area? how to put the new one in?
You don't need a special tool. Jab a screw driver in between the block and the seal and pry it out. Lightly sand the surface of the crank shaft where the seal rides to give it a fresh break in surface. Clean it off. Then put a little oil around the crankshaft and tap in a new seal with a small hammer. That seal tends to be real easy to put in.
Kurt
