  • 1994 - 1995 Specific Tech
another quick question...
  • Thread starter Thread starter MI95Cobra
  • Start date Start date Aug 11, 2007
MI95Cobra
451
Oklahoma City
Aug 11, 2007
  • Aug 11, 2007
with the new heads, cam, and bigger throttle body whenever i'm driving down the street and my rpms are up it sounds like its cutting out or backfiring or something.....i don't loose power and i have it times at 14*......does that mean i need a bigger exhaust like maybe a 3" or does it mean i need a dyno-tune bad???
i currently have a 2-1/2" exhaust....
R
red95gtconvert
382
Ponca city, OK
Aug 11, 2007
  • Aug 11, 2007
Check for vacuum leaks, could be lean misfire.
rj95svt
422
Hayden, AL
Aug 11, 2007
  • Aug 11, 2007
+1 look for a vacumm leak. It's not uncommon to have a vacumm leak after doing H/C/I work.
Dino Dino Bambino
1,673
90
79
Cyprus
Aug 11, 2007
  • Aug 11, 2007
A vacuum leak usually causes a high idle so if your engine does idle high, look for a vacuum leak especially where the lower intake is bolted to the heads.
A 2.5" exhaust is more than big enough.
MI95Cobra
451
Oklahoma City
Aug 11, 2007
  • Aug 11, 2007
ok...thanks....i'll look...
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 11, 2007
  • Aug 11, 2007
Jimmy
Good advice from all
Be sure to look at E V E R T H I N G you disturbed during that recent project
A L L hoses, electrical connections, bolts, etc, need to be just as delivered
from Ford :Word:
It only takes one or two of those little things to make your car a totally
disappointing experience every time you drive it
One last thing ...
you did run ALL lower intake bolts multiple times for correct tightness ... Right!
Grady
MI95Cobra
451
Oklahoma City
Aug 12, 2007
  • Aug 12, 2007
grady...yep i used my chilton manual and torqued them to the specifications the manual stated....i also got new grade 8 bolts for the lower intake, plus used arp head bolts....i'm gonna look all over my hoses again...it was 100* here and it made it really difficult to want to go look at my car today...maybe early in the morning....
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
