Another steering column question
  • Thread starter Thread starter allcarfan
  • Start date Start date Aug 20, 2006
allcarfan
The Answer Man
2,458
North Atlanta
Aug 20, 2006
  • Aug 20, 2006
1966 mustang
Can I remove my steering box and shaft in the column as one piece and replace it with a 1" DD shaft with no Steering Box on the end of it so I just have a DD shaft exposed in my engine bay? Or is the end of the stock shaft where the steering wheel is threaded/splined?
Shane
1966conv
220
  • Aug 21, 2006
Not exactly sure what you mean by dd shaft. (could just be brain dead this am) The 66 steering box and shaft are one piece and 3/4 inch.
Are you asking if you can convert it to a 68 style, with a rag joint type setup? You won't be able to use a 66 box that way unless you have a 66 steering box converted to a 1 inch short sector shaft by the guy at stangersite. You can't use a 68 steering box because th pitman arms are not the same and I don't know what will happen using a 68 pitman with the rest of the 66 steering components. (I actually did have a box converted for that purpose)
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
84 Mustang Steering Column
  • gunnylama
  • Mar 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2025
gunnylama
T
Aftermarket Steering Column
  • Tas_Jak
  • Jul 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 18, 2025
Tas_Jak
T
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
