Another Windage Tray Question
  • Thread starter Thread starter TheBocSez
  • Start date Start date Feb 24, 2006
TheBocSez
652
Converse, TX
Feb 24, 2006
  • Feb 24, 2006
I have searched windage trays and didnt find the answer to this question so maybe you guys can help.
I have a windage tray for my 5.0 that I want to install. I dont know the brand but it was on the engine when I bought it. The engine came with an aftermarket oil pan and pick up also.
I have a brand new stock pan and bought a new stock pick up and melling oil pump to install.
The tray fit fine with the aftermarket stuff, but with the stock pick up, it wont go over far enough and the rod bolts hit it during rotation.
The pan is marked for "Front" which puts the shielded side of the tray on the same side of the engine as the pick up.
Now, I can put it on with the "Front" towards the back of the engine which moves the shielded portion of the tray to the non pick up side and I have absolutley no interference at all. The cranks spins fine with no contact. The only possible problem I could see is that there is a small possibility that the dipstick may hit the windage tray when put in. Worst case scenario I can see with that would be that when putting the dipstick in, it gets caught in the tray and ends up between the tray and the crank instead of into the rear sump.
Can you guys think of any reason why I couldnt mount the windage tray that way (backwards)?
Thanks
timewarped1972
642
mesa, az
Feb 24, 2006
  • Feb 24, 2006
well i'm not sure but depending on the rotation of the crank and which way it "whips" the the oil it may need to go on a certain way.......
i put one on an older 302 i built but it was a non roller/standard pan engine and had no issues
TheBocSez
652
Converse, TX
Feb 24, 2006
  • Feb 24, 2006
Yeah, thats something I was wondering too.
TheBocSez
652
Converse, TX
Feb 25, 2006
  • Feb 25, 2006
Anybody with knowledge in fluid dynamics have any input?
rd
3,316
63
109
Ocean Springs MS
Feb 25, 2006
  • Feb 25, 2006
While I do have some professional knowledge of fluid dynamics, it mostly in the area of gettting water and alcohol mixtures to flow by gravity.
I would think if the tray fits, clears the crank, rods and oil pump, it would be at least somewhat effective.
TheBocSez
652
Converse, TX
Feb 25, 2006
  • Feb 25, 2006
That makes sense to me too, but there would have to be some reason that all windage trays I have seen, are shield biased towards the pick up side of the block.
TheBocSez
652
Converse, TX
Feb 25, 2006
  • Feb 25, 2006
well, I guess it dosent matter anymore. Its on there and everything seems to rotate fine. Oil pan and TC are bolted back on so unless someone know of some catastrophic failure thats going to occur, its a done deal.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
