ANY HEAD SUGGESTIONS???
  • Thread starter Thread starter ritter5.0
  • Start date Start date Jan 25, 2011
1 of 2 Next Last
R
ritter5.0
48
fort drum, ny
Jan 25, 2011
  • Jan 25, 2011
I AM GOING TO BUY A PAIR OF HEADS BUT HAVING A HARD TIME CHOOSING.
I WAS THINKING OF GOING WITH TRICKFLOW 190CC, AFR 185CC WITH A 72 CHAMBER COMBUSTION, OR AFR 205. I PLAN ON PUTTING A 331 STROKER MOTOR IN THE NEAR FUTURE. I WANT TO BE ABLE TO PUT THE HEADS ON MY STOCK BOTTEM END FOR NOW BUT DONT KNOW IF MY BOTTOM END CAN HANDLE THEM ANY SUGGESTION???
HERE ARE SOME MODS OF MY CAR:
trickflow upper and lower
mass air conversion
cold air
75mm acufab throttle body with spacer
fuel pressure regulator
e-cam
pullies
410 gears
long tube headers x-pipe no cats
bigger fuel pump 255
msd ignition
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Jan 25, 2011
  • Jan 25, 2011
why in the hell do you want a 72CC chamber on a NA car?
Shakin66
628
Waycross, Ga / Lake James, NC
Jan 25, 2011
  • Jan 25, 2011
While your at it check out Dart's Pro one heads. I have been very happy with mine.
stykthyn
5,232
2,652
223
gainesville
Jan 25, 2011
  • Jan 25, 2011
My bad, wrong kind of head
F
FoxGT87
5 Year Member
Aug 1, 2009
1,518
St.pete FL
Jan 25, 2011
  • Jan 25, 2011
Could fit two .... err nevermind i digress.
Admin Dude
Jan 4, 1985
43,576
21,741
234
Box behind Walmart
Jan 25, 2011
  • Jan 25, 2011
It's just damned scary that I was thinking along those same lines.
My reply was going to be something like, "Females are preferable but not required depending on which side your door is hinged."
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jan 25, 2011
  • Jan 25, 2011
Well done, styk.
I'd prefer the Trick Flows.
I also have no idea why you'd want 72cc heads on an NA 302. You'll have no compression ratio.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Jan 25, 2011
  • Jan 25, 2011
that would be like 7.9 compression lol. get some tfs twisted wedge heads, or some vic jr 210's, they work like a champ! and throw that POS E cam out the window. you want around a 60cc chamber for a small block ford, regardless of if ya want to boost it, (which boosting a 331 with the stock block is a waste of money anyway) or high compression.
fiveohwblow
Official Member
2,169
145
155
Jan 25, 2011
  • Jan 25, 2011
Friend, that is NEVER wrong.
R
reefblue331
millersville,Md
Jan 25, 2011
#10
  • Jan 25, 2011
  • #10
Twisted Wedge 185cc- factory CNC ported. Matched with a 331 stroker and a Comp Cam custom blower cam. Initially made 549rwhp @ 8lbs boost. Redynoed with reduced timing only- 500rwhp. Also has Holley Systemax FI with Anderson Power Pipe. If I upped the boost to 15psi and increased the timing and in my case, bigger injectors, 625rwhp could easily be obtained. I believe i found a winning combination of parts that produces big numbers and the foundation of all of it are those Twisted Wedge heads I'm sure. Just my 2 cents. Good Luck.
7upstang91
936
124
74
Florida
Jan 25, 2011
#11
  • Jan 25, 2011
  • #11
E7's should get the job done...
fiveohwblow
Official Member
2,169
145
155
Jan 25, 2011
#12
  • Jan 25, 2011
  • #12
^ this
torch93
143
bakersfield c.a
Jan 26, 2011
#13
  • Jan 26, 2011
  • #13
I'm running AFR 185s with x cam, and typhoon intake ( switching intake out soon) and she running pretty dam good.
Boosted92LX
5,721
4,244
224
Jan 26, 2011
#14
  • Jan 26, 2011
  • #14
NikwoaC said:
Well done, styk.
QUOTE]
+1..... I swear this is the funniest dang group I've yet to find on the 'net!...
Y'all are better than watching 2 1/2 men...
Hey, Nik, I was fixin to post stating that I was about to buy some AFR 225's for my 408 build. Why do you prefer trick flows? cost, performance?
stykthyn
5,232
2,652
223
gainesville
Jan 26, 2011
#15
  • Jan 26, 2011
  • #15
Afr uses a gt40 design. Twisted wedges are a competely different design. Imho they are more efficient. I would go trickflow unless I got a screaming deal on afr.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Jan 26, 2011
#16
  • Jan 26, 2011
  • #16
they are good to a certain point, for a mostly stock 5.0 they are good, really the only thing they are good for I think is the valve placed back farther, so you can run a bigger cam. But they do perform! Im kinda feeling mixed up about em lately.
Boosted92LX
5,721
4,244
224
Jan 26, 2011
#17
  • Jan 26, 2011
  • #17
Well, I've done so much research my head's still spinning. from what I can tell,
AFR's are cnc ported, tf's are "fast as cast" unless you spring for porting...flow #'s and dyno pulls are pretty close from write ups I've read.
Tf's do leave room for improvement over afr's with porting.
For what I'm doing I've gotta buy special pistons exclusively for tf's if I chose them.
If I chose afr's I can swap to other inline heads no prob with same pistons..
AFR's are around $4-500 cheaper for 225's.
Ugh my head hurts. no pun intended.
Feel free to politely correct any of this if it is wrong....
fiveohwblow
Official Member
2,169
145
155
Jan 26, 2011
#18
  • Jan 26, 2011
  • #18
Which trick flow head are you looking into?
Boosted92LX
5,721
4,244
224
Jan 26, 2011
#19
  • Jan 26, 2011
  • #19
aw, man, you had to ask. let see if I can find it again. info overload.
Boosted92LX
5,721
4,244
224
Jan 26, 2011
#20
  • Jan 26, 2011
  • #20
here..
ok, these were cnc ported...that 's where the extra cost came from...don't know if that's really a fair comparison...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=220487235973&viewitem=
1 of 2 Next Last
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
SN95 New Heads
  • Blakeknight
  • May 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2025
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
13K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
