Any idea on how to remove rust spots on fuel rail?
str8stang036
1,382
Miami
I have tiny rust spots all over my fuel rails. I have tried fine sanding, and something else that I cant remember. Any of guys had luck using anything else?
Take some Mothers metal polish, and fine steel wool...give it a rub down and that should cure it....its stainless steel, so hopefully its not pitted....i give mine a douche in that stuff everytime i can get at it....
Mothers or any metall polish should have it looking like this....stainless normally cleans up decent....same as the stock tails will...
The three fuel rails I've worked on have been chromed steel. You can use Lime-away it will chemically remove the rust and not leave scratches in the chrome. I then take spray rust converter and wet a q-tip and treat the rust spots so they don't rust again.
