I was reading another post and someone mentioned rear end chatter from not using friction modifier.
Here is my problem. I started having this vibration only while decclerating in 3rd gear and it seemd that it was only when i upshifted to third. If i downshifted to 3rd it didnt do it. Then it was the same in 5th. Now it seems that it does it in 2nd and 4th also.
I checked to see if the bolts on the ujoint were loose and they are tight.
I also had 4.10's installed last summer and it didnt do it directly after the install.
So what do you guys think? Tranny, ujoints, rear end?
